- 10 Aug 2015
Evening all
I currently have a Fractal Define Mini C case with a mATX board and 2070S GPU
I've just got a MSI 3080 and the card length is 325 which is 10mm to long, so need to remove a 140 fan from the front of the case. I can move the fan to the top, currently had 2 x 140 blowing air into the case from the front and 1 x 140 fan at the back
The other idea was go for a new case Corsair 4000D airflow and have better airflow all round
Would the 3080 find it to hot in the Fractal as its not really a airflow case like the corsair. Does having loads of fans make it any louder or because its got more cooling the fans very slower. Also what about dust is there much dust with a airflow case ?
Thanks in advance
Thanks in advance
