Fractal Define R6 PWM Fan Hub
27 Aug 2019
Having just upgraded my PC with an MSI B450 Tomahawk Max board and Ryzen 5 3600 into the Fractal Design R6 case. I am looking at the fan set up using the Refine 6 PWM fan hub. I have four 3-pin fans currently in use but if I've understood things correctly I need to install at least one PWM 4-pin fan to be able to monitor all the system fans using something like Speedfan software or the BIOS screen. Also, when connecting the PWM hub to the MB, should I use the CPU_FAN connector or one of the SYS_FAN connectors ?
All 3 and 4-pin fans have a speed reading wire. The extra pin is for PWM control, rather than feedback.
So you should find that reading speeds works fine but there will only be a single reading, usually from the fan connected to the first slot.
Connect to any slot, if the CPU cooler is connected separately, let that fan keep the CPU_FAN header.
I have the same case and mboard with a 3700x, I am running cpu fan directly off CPU header and the case fans are connected to the hub with the hub plugged into fan 3 header, but as they are 3 pin connectors there is no speed reported in the bios, case fans seem ok, CPU fan goes up and down like a yo-yo, so not happy with that at the moment, might replace stick cooler with a dark rock 4 I have sitting around, just need some thermal paste and the enthusiasm to swap it over.
You will get that with recent Ryzen. Is the BIOS fully up to date?
Have you tried setting a custom fan curve? Sometimes the default fan curves can be "stepped" so you can really notice the differences between temps but if you make your own with more of a curve or slope then you may notice the changes less.
