Fractal Define S Front Panel Mod
24 Jun 2015
https://www.mnpctech.com/blogs/news...mesh-custom-replacement-front-bezel-plate-mod
https://ibb.co/JjdFJMC
JjdFJMC
Good evening everyone,
I was wondering if anyone has a Modded Define S Front Panel like the above link for sale or would be willing to mod mine as I don't have the tools? (Of course, I'd be paying for this)
Ideally, I would like it exactly the same as the above, but with the Meshify C black mesh grill, but straight mesh, not the crinkled mesh.
Many thanks,
Adam
Making that cut in the front panel would be very difficult to do and get a good finish. Just saying. I think you might find that an acceptable job would be more expensive than a new case.
This is a Define S. I bought some "Computer Mesh Case Fan Cooler Dust Filter Network Net Case Dust-proof Covers" from the auctions for under £8. Then used a dremel to cut out the front with around a one inch remaining rim. Then double-sided tape and glued a piece of mesh to the front. I've also put thin strips around the sides on the inside which means I don't need the inside filter panel. Really isn't hard. It means you don't have to worry so much abot the front being perfect because you can only see the mesh. It's a meshify thing. Looks better than that pic.
Oh, and a massive increase in cooling. Those fans are attached to a 360mm rad which is much more effective now.
