- 10 Mar 2009
- Newark
Hi, So i recently received my new case, the S2 vision for my new ryzen build.
I am trying to piece together the pieces ready for a water cooling build.
I am a little confused regarding the radiator. I am wanting to top mount it, and i am wanting a 360 radiator. Trouble is am not 100% sure what thickness radiator the case will support. The thing that is throwing me off is that the booklet says it supports 120, 140, 240, 280, 360 to the top. But then it has two lines pointing to the 140 and 280 saying 35mm max. Which i assume means maximum thickness for the 140 and 280 is 35mm which is fine.
But why would the 140 and 280 have a maximum thickness and the 360 not? Anyone fitted a 35+ 360 radiator in the top case. or any one have any idea's?
I am well out of the game with things like this, last time i touched cooling was when i had a Vapochill LS on my athlon 64
