Fractal Design Case or other help to choise ?
9 May 2009
Hi all
I still have my heart set on a Fractal Design Case but was woundering if there was anything better than this ?. I like the fact that the new fractal case is built around keeping sillence in mind.
whta to do you think i should do, can any one give me any suggestions.
thanks
I am about to buy a new system, usually I just buy mobo etc and place the new components in my Chieftec Dragon I bought many many years ago. I currently have an 8800GTS and it is tight. The 5850 from my new build might fit if I could take out an HDD cage but I need the drives so for this build I decided I needed a new case.
I looked at every case I could find and made a list of sizes of the cases and video cards. I am sure someone will correct me if I am wrong but a 5970 is around 31cm. The Fractal design takes up to 29cm, so even if you can get it to fit it is going to be tight.
I don't have a 5970, I am buying a 5850 so the Fractal design was high on my list. However I may get a 5970 in the future so it seems to make sense to buy the biggest case you can get away with both in cost and available space or be prepared to change your case a few years down the line.
I want a good case and don't want to buy another for a few years so I am possibly splashing for either the Corsair or a Lian-Li full Tower, both of which should see me through as long as the Chieftech Dragon has.
I see there is a new Fractal Design in the pipeline and everything I have heard about the current one makes me want to buy one now and worry about larger cards later.
There is no clear answer unfortunately, you need to think about what you want in it, how many HDD's, GPU's and other cards you need to fit in and select one based on budget and what one suits you (that you like the look of).
Good luck.
I Bought a Fractal case for my Home server build.
Yes you are a little limited in the space from the edge of the motherboard to the edge of the drive bays. I have just measured mine and it is roughly 300mm from the flat edge of graphics card (not including the 90deg lip where the retaining screw goes) to the lip of the 8 drive bays (you could possibly fit 310mm if you very carefully angled it in place (passed the drive bay lip, but I wouldn't buy once to test if I didn't already have it).
The case is very good for my needs (a little more plasctic than I expected) but the drive bays cannot be split like in some cases (its either all 8 bays or none at all - unless you used a Dremel !).
I was going to go for one of these but with gfx cards getting bigger I decided against it and went with a HAF 932. The inside space on a HAF 932 is 32.3cm from back to HDD cage.
