Fractal Design Cases with Optical Drive Bay?
15 Oct 2003
Nottingham, UK
Hi,
As per subject, are there any fractal design cases which allow for a single Optical drive? Can't seem to find any?
it is a standard fit for that case, open the front door and it is the top slot above the 2 x 140mm fans. In fairness, there isn't a clear image of the optical drive bay on the OCUK website, but trust me, it is there
The R5 is basically the same except it has two 5.25" slots rather than one. They are both very nice cases. Very understated but they are very wide and really grow on you. Plenty of space for coolers and fans.
you can stick one in the r6 but you have the have the hd's in the standard layout if you want the open layout like i have in the define r6 thread in here you have to take out the bay and cant use one :)
