- 7 Apr 2017
Hi all, wondering if anyone can offer some advice. I have the above case with the two pre-installed push pull fans mounted with are directly inline with my Noctua D14, so my CPU even overclocked is nice and cool and my VRM temps have never gone above 46 degrees. I have however noticed that my GPU is starting to throttle itself when the PC has been on a few hours gaming. I've put a custom fan curve of which keeps temps nice and low, but means the GPU fans are spinning up at 60-100% intermittently.
I'm wondering if it's worth getting a couple of Fractal silent fans (same as ones that came with the case) and mounting these to the bottom of the case to draw air out and if this will make a worthwhile difference. Any advice on this greatly appreciated!
