Hi,
Is there anyway of improving the cooling on a Fractal Define 7?
I'm using the case for a homeserver with 8 drives in the bays.
The 3x 140mm fans in the front are keeping the drives cool but no air is getting through the bays into the motherboard area, have tried adding a 120mm fan to pull air through but made no difference.
On the image below the red area is where the heat is sitting, there is no GPU and CPU is only a 3400G.
PCI cards installed are:
RAID card (I suspect most of the heat is coming from this as is very hot to touch)
2x tv cards
1x NIC
Fans are:
3x Noctua 140mm 3000rpm (intake)
2x Akasa 140mm
2x tv cards
1x NIC
Fans are:
2x Akasa 140mm
than have the top 2 fans removing the air.
