- 4 Dec 2012
Would the Fractal Design Define Mini (micro ATX) case have enough room to fit a Noctua NH-D14? I do have low profile memory so that's not a problem links below, if it does fit is it also compatible with FM2+ socket motherboards? one more question with this build as you probably already noticed I'm going for complete silence whats the best noctua silent fans available? I'll need 3 altogether two for the front as intake fans and one at the back for an exhaust fan, thanks
Cooler
http://www.overclockers.co.uk/showproduct.php?prodid=HS-011-NC
Case
http://uk.hardware.info/reviews/3149/9/12-micro-atx-round-up-compact-chassis-fractal-design-define-mini
Cooler
Case
