Fractal Design Define Nano S - mITX Watercoolers dream?
30 Dec 2013
GPS signal not found. (11)
The Define Nano S is an ITX case that features compatibility with high end, full-size components, superior sound dampening, and an ATX-like layout.
The case includes two Dynamic Series fans with both bottom and front intakes protected by easy-to-clean, removable dust filters.
With its mounting capabilities for simultaneous radiators and unobstructed airflow path, the Define Nano S can cool enthusiast-level components.
Equipped with Fractal Design’s signature ModuVent™ technology on the top vents and sound dampening throughout, the Define Nano S can run a powerful system quietly, a hallmark of the Define series.
Key features
  • A Define Series ITX case designed for silent computing with sound dampening and ModuVent™ technology
  • User-friendly construction with superior cable management and compatibility for full-size components
  • Flexible storage options with room for up to 4 drives
  • Accommodates a variety of radiator sizes and includes brackets for reservoir and pump mounting
  • Features two Dynamic Series fans — 1 GP-12 and 1 GP-14 — with an adapter included for motherboards with limited fan headers
  • Featuring an open interior allowing an unobstructed airflow path from the front of the case to the rear exhaust
  • Easy-to-clean filters on the top and bottom, spanning the PSU position, with the bottom filter ejecting from the front for easy-access.
Expect a price around £50 :) and availability from March at the earliest :(
Specs and numbers and things
Specifications
  • ITX motherboard compatibility
  • 2 expansion slots
  • 2 - 3.5" HDD/2.5" SSD positions; 2 - 2.5" dedicated SSD unit positions (fits SSDs up to 13mm thick)
  • 6 - Fan positions (1 Fractal Design Dynamic GP14 140mm fan + 1 Fractal Design Dynamic GP-12 120mm fan included)
  • Filtered fan slots in the front and bottom (ejects from the front of the case)
  • CPU coolers up to 160mm in height
  • ATX PSUs up to 160mm deep
  • Graphics cards up to 315mm in length with front fans mounted (Cards wider than the dual slot bracket are not recommended)
  • 17 - 35mm of space for cable routing behind the motherboard plate
  • Velcro straps included for easy cable management
  • Both side panels and rear HDD/SSD brakcets feature smart captive thumbscrews
  • Dense sound dampening material on front and right side panels; left side panel includes a transparent window
  • ModuVent™ on top of case for further silent computing or additional ventilation
  • Colours available: Black
  • Case dimensions (WxHxD): 203 x 330 x 400mm
  • Case dimensions - wtih feet/protrusions/screws: 203 x 344 x 412mm
  • Net weight: 4.6 kg
  • Case volume: 26.80 litres
  • Package dimensions (WxHxD): 275 x 485 x 420mm
  • Package weight: 5.8 kg
Cooling system
  • Front: 2 – 120/140 mm fans (included is 1 Fractal Design Dynamic GP14 fan, 1000 RPM speed)
  • Rear: 1 – 120 mm fan (included is 1 Fractal Design Dynamic GP12 fan, 1200 RPM speed)
  • Top: 2 - 120/140 mm fan (not included)
  • Bottom: 1 – 120 mm fan (not included)
  • Dust filters: Bottom and front intakes
Water cooling compatibility - Radiators
  • Front – 120/240mm, 140/280mm (max width 147, length 312; some radiators extend beyond the screw holes)
  • Top – 120/240mm (max component height on motherboard 35mm. Big heatsinks on RAM or power regulators around CPU could conflict with this restriction)
  • Bottom – 120mm (max thickness & length: 85mm x 160mm)
Water cooling compatibility - Pumps
  • Pre-drilled holes on multi-bracket, supports many DDC and D5 variants (see manual for detailed measurements)
Water cooling compatibility - Reservoirs
  • Adjustable mounting brackets allow for almost any rectangular mounting screw pattern. Maximum distance between the mounting bracket screw positions: 270mm height / 80mm width.
Front interface
  • 2 USB 3.0
  • Audio in/out
  • Power button with LED (blue)
  • HDD activity LED (blue)
  • Reset button
Package contents
  • Define Nano S - Window computer case
  • User manual
  • Accessory box
Hexus writeup
Tom's Hardware writeup
Product Page
I love cases built for watercooling that aren't the size of a small bear. I like it even more when they are the size of a small dog.
If you can get a rad in the front and a rad in the top at the same time then this could be my next case.
I think it does. The tom's article has a picture showing the radiator space and the video previews one with 2 AIOs.
That's a pretty nice looking case. Great water cooling options. If I were to go back to a custom loop this is what i'd go for, fed up of silly large cases now.
Still no fan filters on the top? :(
Use them as exhaust. Or make your own. Personally I don't use fan filters for anything except power supplies. It takes months and months of dust to increase temperatures as much as the filter does.
Just a bit of info i've just come across in TTL's review of this case, if you have a Asus Impact ITX board or any of the other ASUS boards with the riser card at the top, you can't fit a rad in the top of the case as it won't fit as it fouls on the riser card, you can still fit one in the front, but if you want one in the front and already have a Asus board with the riser card, or are planning one it's something to be aware of. :)
