Fractal Design - Define R6 Blackout Type-C
Hi Guys,
Does anyone have this case and could answer a quick question?
(https://www.overclockers.co.uk/frac...t-type-c-midi-tower-case-black-ca-07s-fd.html)
I'm wondering if it will accept a 240mm radiator in the roof of the case, specifically the Corsair H100i V2.
Cheers
I have this case, and I'm also using a Corsair H100i v2 in the roof, along with a Blu-ray drive in the top bay. The only thing I will say is I'm using this RAM: https://www.overclockers.co.uk/team...al-channel-kit-grey-tlgd416g30-my-087-tg.html and it just touches the radiator, so you may have issues with tall memory modules.
Update - 240mm fitted fine in the roof of the case, I was assuming it would be pre-drilled holes in the case for the screws but it's simply a rail which the screws pass through, therefore you can "slide" the radiator in to position and then tighten the screws.
As alluded to earlier though, I would say that fitting an optical drive may be quite tight depending on where you place the radiator.
