guys im using 2x fractal design dynamic x2 140's in the front as intake , 2x fractal design dynamic x2 140's as exhaust in the roof and my cpu cooler is the corsair h60 with fans in push pull config set up as exhaust out of the back of the case and the case is getting a bit hot inside.
the fans are 3 pin on the 3 pin fan hub connected with the sata cable so they are getting full speed non pwm.
can someone please recommend some 140mm fans which will shift more air that the dynamic x2 does without RGB
, they will be connected to the 3 pin i dont need pwm.
thanx in advance
, they will be connected to the 3 pin i dont need pwm.thanx in advance
