fractal design define r6 fan hub question
13 Mar 2010
im going to buy this case but i would like to know how the fan hub works with my 3 pin case fans and my asus strix z270h motherboard.
i dont know how to connect this up properly, it says you need the cpu fan connected to it? but what about the aio corsair h60 pump which runs at full rpm all the time? also i would like to be able to turn off my 4 3 pin non pwm case fans in my motherboard software fan expert 4 but im not sure how this would work as the fan hub connects to the motherboard with a 4 pin pwm cable? and which port on the motherboard does it go in to?
can anyone help me?
thanx
