Also, has anyone found a way to mount a 3.5" drive with the shroud mounted all the way back?
You can mount 2 vertically on the back of the shroud.
Hi I've been emailing Fractal support directly and they have been extremely helpful but would anyone know if a rad with these dimensions 460 x 140 x 40 mm fit in the top of the case with the front shroud in the back position?
They will have the spares available, just at a later date.
Quick question: can the feet be removed on this case?
I think you can, I don't own the case but know you can put a glass panel on the back also.Received my one of these today, accidentally ordered the one without the glass side panel. Does anyone know if you can order the side panels seperately? Alternatively,anyone want to swap a glass panel for a metal one?
Well I have been waiting so long their own systems removed the query and I had to re-add it...
What is the point of selling an incomplete product? Not just HDD trays but also that GPU bracket is still not out... It's damaging Fractals rep IMHO
Not removable..they used some adhesive on it
As of the latest update (19/02/2018), Fractal are still obstinately refusing to "consider offering" TG side panels or additional drive trays as seperate purchases: http://support.fractal-design.com/s...r-additional-hdd-ssd-trays-for-the-define-r6- , even though you'd think the very fact that it's a listed as a "FAQ" would in itself be a bit of a giveaway.
It's really beyond irritating that buyers apparently have to beg for the privilege of being permitted to purchase spare parts; maybe Fractal's recent success has gone to their collective heads and led to a certain arrogance and contempt towards their paying customers.
I'm really NOT impressed with Fractal... they have released a product which has stock issues. Their "parts store" lists a single part for the R6 (the flexi cable at 10X the ebay price) which is NOT IN STOCK and there has never been a single entry even for the new HDD sleds.. What is the point of a box that can take 11 HDDs if you cannot get (new, or used - I drop strong hints here I am willing to buy) the parts needed to do so.
I have owned Define R3 and R4, currently have an R5, S and XL but I'd prefer to be able to manage my systems down to a loaded Threadripper box full of HDDs, GPUs and VMs.. but I cannot... Don 't they want MORE of my money?
Yeah screw that I won't be buying a glass sided case when it can go bang and no chance of getting a spare side.As of the latest update (19/02/2018), Fractal are still obstinately refusing to "consider offering" TG side panels or additional drive trays as seperate purchases: http://support.fractal-design.com/s...r-additional-hdd-ssd-trays-for-the-define-r6- , even though you'd think the very fact that it's a listed as a "FAQ" would in itself be a bit of a giveaway.
Well after finding a non windowed one that was B grade stock at a local computer retailer I went down and had a look to see if it had all the parts etc. Reason for b-grade was a slight paint imperfection on the top so as its for a file server not a show build I took the plunge and brought it for £97 to put in motion the 1st part of my cunning plan. Now I am going to buy a toughened glass side panel version to house my next gaming system that I will purchase after the new ryzen cpus come out in april and use the hard drives sleds from this to fully populate the file servers slots.
I'm sure you posted that JUST to make me groan... Its the only way to get sleds it seems
How many sleds are you after?
