1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
Fractal Design Define R6
Discussion in 'Case Central' started by southernorth, Dec 20, 2017.
  1. RSR
    Sgarrista
    Lovely build, is that Glass or PETG?
  2. khemist
    Mobster
    PETG.
  3. RSR
    Sgarrista
    Nice! Did you polish the PETG to get it that shiny?
  4. khemist
    Mobster
    No, it's EK HD tube, it's much more clear than the Bitspower stuff.
  5. Smffy
    Mobster
    Nice tidy build, is that Barrow digital sensor on eBay? Given it a google but can’t find it, looks much more refined than other massive screen read outs... pm a link if you can’t post it :)
  6. khemist
    Mobster
    Search ebay for barrowch digital OLED display - no Black ones left though.
  7. Smffy
    Mobster
    Thanks, is this someone ripping off Barrow?? Why the CH on the name...
    Edit: looks like the same company, god knows with business in China though ;)
  8. khemist
    Mobster
    Not sure if it's just an updated name or an offshoot of Barrow.
  9. Smffy
    Mobster
    Links to Barrow support on the website, appears to be some sort of china outfit which uses their products or parts. Completely trust Mizo on the bay anyway!
  10. khemist
    Mobster
    Yeah, I've bought a few smaller bits there no problems.
  11. TheSwede
    Wise Guy
    For some reason FireFox don't like your image service. Well, not for me anyway. :confused:
    I did check your images in Chrome though, so I know you have a full water build, but I seen you posting other builds so you, (among others as well), knows better then me. So I thought that I ask you slightly directly since you owning the same case. :o
    In any case, was going to ask you (or anyone else that might know), the following. I am using a AiO cooler for the CPU. Halfway assembling it and when sorting out cables on the back I realized that the case PWM Fan Hub have a connection to the CPU_FAN on the mother board. Did I assume right that the AiO connection that suppose to be in that socket is instead going to the Fan Hub, where the "Main 4 Pin PWM CPU fan" would been connected if using the CPU fan that comes with it ?
    Just wanting to be sure before I finish the build and switch it all on. Would be a shame if I get a fizzle and nothing else when I do ! :eek: :o
  12. khemist
    Mobster
    Should be fine, post a pic when you are up and running.
    Are you just going to use the stock case fans?.
  13. TheSwede
    Wise Guy
    Was thinking doing that yes, one at the back and maybe one at the bottom, depending if I can sort out the cabling down there properly (wont be using any at the top though). Or you got some better ones in mind ?
  14. killem
    Gangster
    [​IMG]
    Hope this helps
  15. Delhi
    Hi, I've read the whole thread.
    I'm looking at the possibility of building a server and I need as many bays as possible 3.5
    I think I've found the solution, I hope it helps, bye
    [edit] Exactly how many 3.5 bays do you enter?
    thanks!
    Are individual parts available for sale? Such as additional HDD cages or side panels?
    Modified on: Wed, 28 Mar, 2018 at 12:12 PM
    We have a German spare parts shop from where you can order and buy parts and accessories.
    Here's link to the shop: http://www.fractal-design-shop.de/
    Right now, we only have shipping of bigger products within Europe.
    Fractal Design Support
  16. Viberious
    Wise Guy
    I recently brought 5 from Ebay taking my total to 11, only downside my plans for the R6 changed. Not sure if will convert my rig from my primo to the R6.
  17. Delhi
    Thanks, looks good
    [​IMG]
  18. khemist
    Mobster
    Flex VCR-25 riser cable has been released, mine should be here in the next few days.
  19. nyknight
    Please help, I cannot find it on ebay. I do it see on the german Fractal spare parts store for $6.90 euro + shipping. Not sure if that's just 1 tray or 6 since there is no picture. But spec says 0.3kg, so that's pretty heavy for just 1 tray. https://www.fractal-design-shop.de/Define-R6
  20. Viberious
    Wise Guy
    It was a private sale and not connected to Fractal Design.
