You may have an issue finding somewhere to mount is as there aren't a lot of 120mm fans in the XL. You could probably do it with a 120-140mm adaptor but you'll need to be really careful with the screw lengths so you don't puncture the rad, although the pipes may be long enough to run it to the front 120mm as an intake which would be ideal...
