** FRACTAL DESIGN NODE 202 - FINALLY IN STOCK!! **
26 Nov 2014
Stoke
It's taken a crazy amount of time but the Fractal Design Node 202 is finally sat in our warehouse. There were a few issues with a small amount of the PCI-E riser cables and rather than risk sending out cases with problematic cables, Fractal delayed the shipment to make sure that every unit worked great.
I know there's a lot of interest around these and for good reason. It's a great feature rich chassis and perfect for anyone planning to build a console killing rig. Stock is pretty limited on these and we've already had a lot of preorders get pushed through, so be quick :)
Fractal Design Node 202 Mini-ITX HTPC Case - Black @ £69.95 inc VAT
The Node 202 is the ultimate PC case for those looking for a beautifully designed, compact chassis that can house a capable gaming build.
This small footprint is an intelligently built unit where extreme detail was placed into the design phase to get every line and spec in perfect harmony. With both horizontal and vertical orientation possibilities, the Node 202 can be placed anywhere in the house. The sleek design makes it very attractive next to the TV in the living room or on your desk in the office.
The internal layout of the Node 202 keeps the hot components separate and has them all placed in proximity of free-flow air so the case will run cool despite not having any extra case fans.
Features
- Featuring a sleek and elegant design that will fit in any space or room
- Extremely small footprint with a volume of only 10.2 liters
- A highly versatile case that can be set up both vertically and horizontally
- Supports Mini-ITX motherboards, SFX power supplies and graphics cards up to 310mm in length
- Provides a smart thermal interior design highlighting separate motherboard and graphics card chambers
- Strategically placed air filters for a dust free interior
Specifications
- Mini ITX motherboard compatibility
- 2 - 2.5" SSD unit positions
- 2 expansion slots
- 2 - 120mm optional fan positions in graphics card chamber
- CPU coolers up to 56 mm in height
- PSU compatibility: SFX PSUs up to 130mm long
- Graphics card compatibility: Maximum dimension of graphics card is 310x145x47mm (LxHxD)
- Can be placed both vertical and horizontal position
- 3 dust filters included (for CPU, GPU and PSU)
- Case volume: 10.2 litres
- Colour: Black
- Case dimensions - Horizontal (WxHxD): 377 x 82 x 330 mm
- Case dimensions - Horizontal, with feet/protrusions/screws (WxHxD): 377 x 88 x 332 mm
- Case dimensions - Vertical, with feet/protrusions/screws (WxHxD): 125 x 385 x 332 mm
- Net weight: 3.5 kg
- Package dimensions (WxHxD): 145 x 463 x 388 mm
- Package weight: 4.0kg
- Front I/O: 2 - USB 3.0, Audio in/out, Power button with LED (white)
- EAN/GTIN-13: 7350041082675
- UPC: 817301012676
- Product code: FD-CA-NODE-202-BK
Only £69.95 inc VAT.
ORDER NOW
Fractal Design Node 202 Mini-ITX HTPC Case + Integra 450W SFX PSU - Black @ £119.99 inc VAT
The Integra SFX 450W PSU that comes inclusive with the enclosure provides stable power to the most demanding systems. It comes with customized connectors and tailored cables perfectly fitted for use within the Node 202, contributing to hassle-free installation and cable management.
Features
- Includes a Fractal Design Integra SFX 450W power supply with specialized cables for the Node 202 case, providing the right connectors with precise cable lengths
- Quiet and efficient operation at 80PLUS Bronze efficiency with a 3 year warranty
Specifications
- 2 expansion slots
- Colour: Black
- EAN/GTIN-13: 7350041084006
- UPC: 817301014007
- Product code: FD-MCA-NODE-202-AA-UK
Integra PSU Specifications
- 80PLUS® Bronze certification
- 80mm, temperature controlled fan
- Maximum operating temperature at full load: 50°C (50°C @ 100%)
- Fully Intel Haswell C6/C7 compliant
- 3 years warranty
- Taiwanese capacitors
- OPP / OVP / UVP / SCP / OCP Protection
- 100,000 hours life expectancy (MTBF)
- SFX 3.3 PSU specification compliance
- ErP 2013 compliant (<0.5W system power draw)
- Colour: Black
- Unit measurements (WxHxD): 125 x 64 x 100 mm
- Net weight: 1.0 kg
Only £119.99 inc VAT.
ORDER NOW
