Fractal Design Node 202
That is a gorgeous case and would be a wicked emulation system.
I don't think OcUK will stock Fractal for a long long time. OcUK said their quality control was sub par
Glad there's a thread on this. This will be my next case. Looks absolutely gorgeous.
This will be compared to Silverstone FTZ01, but IMO Fractal actually make better cases. I used to be a fan of Silverstone, but their quality has really gone downhill.
£50 quid extra for a 450w SFX PSU is a bit steep. Most people wouldn't even use 200w in a system like that so a cheapo 250w SFX or a Pico PSU Would work out loads cheaper. The design is nice tho, money here for 1 maybe 2 when they land.
Best of luck running a Titan X or 980 Ti on a cheapo SFX PSU then. It's billed as a console killer case, so it's geared up for a top-end graphics card hence the PSU option.
Don't need it, don't get the PSU, but the option is there (much like Silverstone's Sugo SG05 to 08)
I emailed graham @ Fractal again asking if they could send me the dimensions so i could model in Sketchup - they said no (which was expected) :P he also advised that water cooling will not fit and is not needed to which i said challenge accepted :D
Actually, this case competes more with our ML07, which also has plastic outer shell and is around the same price range. I am confident our product quality is not inferior to theirs given the same prices.
The FTZ01's exterior on the other hand, is built out of aluminum unibody with sand-blasted and anodised finish so it has much better quality!
