Hi, the blue power light on my R3 case isn't coming on or showing while the PC is switched on.
The PC boots fine and is running without any problems.
The front panel connectors are connected to the Mobo (Gigabyte Z68).
Should I be concerned? Bit worried in case its the motherboard playing up or it's a symptom of something going wrong.
