- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
Hey guys!
I have a great deal on R3 cases.
Fractal Design Define R3 Midi Tower Case - Arctic White @ £79.99 inc VAT
The Define R3 case is reaching new heights in combining stylish, contemporary design with maximum functionality and noise absorbing features. The minimalistic, yet stunning front panel design, fitted with noise absorbing material on the inside, creates an aura of exclusivity. The patent pending feature ModuVent™, in which you can choose whether to have side and top panels open or not, makes the case appealing for users seeking optimal silence, as well as the performance hungry ones. The sleek black interior is matched with pre-fitted, dense noise absorbing material on the side panels, efficiently absorbing noise and vibrations. You can fit an astonishing total of eight(!) hard drives into this case, using the user friendly HDD-trays. All painted in a nice white color and using black silicone mounts. PSU is mounted in the bottom of the case, with a convenient pull-out filter beneath it. Are you one of those users always ending up with a case full of tangled cables? No more. The Define R3 offers a convenient and good looking way of hiding them away. The motherboard has rubber covered holes in which you can easily route the cables behind the motherboard.
- Stunning front panel design
- Patent pending ModuVent™ design, allowing the user to either have optimal silence or optimal airflow
- Pre-fitted with dense, noise absorbing material
- 8 white painted HDD-trays, with silicone mounting
- A total of 7 fan slots (2x120mm in front, 2x 120/140mm in top, 1x120mm in back, 1x 120/140mm in side panel, 1x 120/140mm in bottom)
- 2x 120mm Fractal Design 120mm fans included
- Fan controller for 3 fans included
- Easily removable front fan filters with clip-on holders for 120mm fans
- Supports graphic card lengths up to circa 290mm and CPU coolers with height of maximum circa 165mm
- 1 rear Fractal Design 120mm @ 1350rpm included
- 1 front Fractal Design 120mm @ 1350rpm included
- 1 front 120mm fan (optional)
- 1 bottom 120mm/140mm fan (optional)
- 1 side panel 120mm/140mm fan (optional)
- 2 top 120mm/140mm fan (optional)
- Case size (WxHxD): 207.4 x 440 x 521.2mm
Improvements from R2
- Improved air flow with updated fans
- Improved noise absorbing material
- Bigger hole in M/B plate for mounting of CPU Coolers
- Improved cable routing possibilities
- Reset button, located behind the front panel door
- Many small quality improvements, including improved scratch resistant coating
Was £89.99 Inc. VAT
Only £79.99 inc VAT.
ORDER NOW
Fractal Design Define R3 Midi Tower Case - Titanium Grey @ £69.98 inc VAT
Was £84.99 Inc. VAT
Only £69.98 inc VAT.
ORDER NOW
Fractal Design Define R3 Midi Tower Case - Black Pearl @ £69.98 inc VAT
- Front I/O: 2 x USB3.0 Ports
Was £84.99 Inc. VAT
ORDER NOW
Fractal Design Define R3 Midi Tower Case - Silver Arrow @ £69.98 inc VAT
Was £81.99 Inc. VAT
ORDER NOW
Was £89.99 Inc. VAT
ORDER NOW
Was £84.99 Inc. VAT
ORDER NOW
Was £84.99 Inc. VAT
ORDER NOW
Was £81.99 Inc. VAT
ORDER NOW
