Fractal Design R4 upgrade
11 May 2010
Hi,
I currently use the Fractal Design R4 case.
After recently getting hold of (and then sending back, long story) a Radeon 295x2 I noticed that my case is just a tad too small for that sort of thing. Although it did fit, I found it hard finding somewhere to put the AIO rad which didn't interfere with something else - and I had to remove a hard drive cage which messed everything up :D
When I upgrade in the nearish future (whenever Skylake comes out) I'm going to be looking for a new case which is perhaps a bit roomier!
I would like something which is a bit low key. I'm not really a fan of LED lighting or windows in the side of the case.
Other than that though I'm open to suggestions!
Thanks :D
Thanks for the sugggestions, I like the look of all of them at first glance. I'll get on some reviews I think :D
