I recently did a new build for a family member using the Fractal Design R5 Black Pearl. I found it was a really nice case to work with and seems to be well sound-proofed. I'm soon going to build a new PC for myself and have considered the R5 but have a couple of concerns.
Firstly the R5 comes with only two fans as standard. I know I can fit more, but this pushes the cost up and more importantly might push the noise up. The room my PC is in gets very hot in summer, so good cooling is important. But so is sound proofing, I don't want some fan-whirring beast. What's the R5 like with stock cooling when the ambient temperature gets high, and does it stay pretty quiet if you fit extra fans? I plan on using a Noctua CPU cooler and likely will use a single GPU (GTX 660 for now, Pascal later).
Secondly, the R5 has way too many HDD trays and 5.25" bays and only two SSD mounts on the back of the tray. I know the HDD cages can be removed for better airflow. But it seems a rather old-fashioned setup. I need to house 2 or 3 SSDs and 2 or 3 HDDs. I'll likely switch to an external DVD-RW so no need for 5.25". Are there any more elegant solutions than the R5? I looked at the Define S but this seems to have even less options.
Are there any alternatives to the R5, where the emphasis is on sound proofing while still having good cooling and tidy well-mounted storage? Ideally at same price point at the R5, but can stretch the budget up to about £120 if necessary.
