fractal design r5 or define s
20 Sep 2011
local
Obviously the define s is more for water cooling and has a bigger window,I like the res mount in it,but the r5 seems to have a bit more quality ?
I'm stuck between these cases
I'm watercooling in a define s. I've not used a R5, though my last case was a R4.
If you dont need the optical drives, and your not intending to hammer your 3.5" drives, then I see no downside to the define s....
If you dont want the cages then get a define s IMO.
I've ordered the define s ,I believe the window is very easily scratched!
