ah ok... well if its the controller that has the sata power cable as well you probably wont need it. lots of cases , fans etc.. can either be controlled by a stand alone controller. or by the motherboard via bios or software. one of my old PCs i use the controller as there is no on board RGB headers. just dont get the 3 pin one, confused with the 4 pin ones. should just have to plug the 3pin cable into the 3 pin mobo port and thats it
