Fractal full tower power supply.
1 Aug 2006
Recommendation's on power supply which will suite the Fractal full tower case.
1. Cables must be long due the nature of the case most important part for me.
2. Very Quite.
3. Do not need big power only have 4 hds and gtx 460 card but may upgrade later.
Thanks jay.
Using a corsair hx 850w here, had to buy an extension for the 4/8 pin cpu power connector, my case is a full tower lian li a70f, psu mounted in the bottom
I've got the Fractal designs XL case and a Antec TruePower 650W modula PS, with a P8P67 pro motherboard and the extra power cable only just fits. It's only just long enough to reach, and when it's plugged in it's not pulling excessively, quite lucky on my part.
Take into account that the extra power connector (EATX12V) is right at the top of the motherboard, but there aren't many places where it can be further away from the PS.
It's also a whisper quiet PS, can't really hear it when it was on it's own in my system when building it.
Is that when routed round the back of the case as should be or through the trap door ?
Also thanks to other posters will check them out.
It's routed as it should be, out the back and throught the top cable management hole. It's a bit tight but once it's plugged in it's fine.
