- 2 May 2017
Hi all,
After having installed a new hard drive in the above case, I now notice there is a low frequency hum/vibration. It stops when I either raise the front of the case, or lessens when i lift the front right leg off the surface.
It's driving me mad (am quite susceptible to erroneous noise) and is very frustrating as it's dead quiet other than that.
Anyone got any ideas?
With thanks.
James
With thanks.
James
It fixed it afterwards. It might be worth checking all of your fans one by one.
