Fractal Node 202
25 Jul 2015
I want to do an itz build and want a small case and can't across the Fractal Node 202. Looks good but I'm concerned about the CPU and GPU temps. I've got the G4560 and plan to get a 1050 Ti with 8gb ram.
Anyone have this case and what are your thoughts?
This is another small case i've been looking at myself. I tried to get a Dan case when it was available for all of 20 mins or so but have the "Sentry" case backed on 1st batch so looking forward to that arriving.
I found one build on ************ where the user details some of the temps here, but it's an i5 and 1060 installed: https://uk.************.com/b/9D3bt6
Then found one with same CPU as you have: https://uk.************.com/b/HZLJ7P
Personally i don't think you'd have much to worry about, you could put some fans alongside the 1050 card as the user on first link has done.
Thanks for that. I think I'll get the thermal take core v1. Was a treat to work on my 1st ever build last year.
Guess potential problem of node 202 is noise and temps at load
I've been looking at the TT Suppressor F1 mITX case earlier, seems to be just the job if the upcoming reference Vega cards are under 255mm in length :)
Thanks, I think I'll go for that. Seems to be the same dimensions as Core v1?
Shame Ncase 1 is really expensive and not so widely available in UK, awesome looking case
