Fractal Node 304 GPU Recommendation
10 Jul 2006
Tredegar Wales
Hi,
Any suggestion for GPU that will fit in the Node 304. I'm using the Asus Rog Strix B350-I MB, Ryzen 7 5700X & 32g of ram. I'll mainly using the pc for photo editing no gaming.
Can you clarify from the website:
"GPU max length
310 mm (when 2 HDD slots are removed; graphics cards longer than 170 mm will conflict with PSUs longer than 160 mm)"
Do you have 310mm available?
Is it max 2 slot?
