- 9 Oct 2013
- United Kingdom
Hey guys,
Would an owner of a Fractal Node 804 case do me a huge favor and measure the distance between the holes of the bottom front motherboard partition (at the bottom of the hole at it's highest position) and the bottom of the case?
What I am trying to determine is which radiators will fit with the ports at the bottom without modifying the case.
Cheers, Nathan
Cheers, Nathan
