2 Aug 2010 at 15:01 #1 ooEy ooEy Associate Joined 27 Oct 2006 Posts 613 Location Cotswolds, Nr Cheltenham What is the best (coolest) set up I can achieve with : Fractal R2 Case Corsair H50 4 x Fractal 120mm 2 x Fractal 140mm It will be cooling a E8400 @ 4Ghz and I also have an overclocked 5850 in there. Cheers
2 Aug 2010 at 16:51 #2 dante6491 dante6491 Soldato Joined 30 Jun 2006 Posts 6,240 Location Horsham Purchase one more 120mm fan. Have 2x120 at the front. 2x140 at the top. Have a pushpull on the H50 at the back, then a 120 on the side.
2 Aug 2010 at 22:33 #3 ooEy ooEy Associate OP Joined 27 Oct 2006 Posts 613 Location Cotswolds, Nr Cheltenham so that would be: Top : exhaust Front: intake Push/Pull rear: intake Side: ??? I'm currently using an Arctic Freezer with top 2 x 140 exhaust, front 2 x 120 intake, rear 120 exhaust and bottom120 intake
3 Aug 2010 at 01:22 #4 momo56 momo56 Soldato Joined 18 Jul 2009 Posts 3,268 I would say have the side as intake to cool the gpu?
3 Aug 2010 at 12:31 #5 ooEy ooEy Associate OP Joined 27 Oct 2006 Posts 613 Location Cotswolds, Nr Cheltenham 1 more quick question. If I connect the pump to a molex can I use the Fractals fan controller for the 2 x 120mm Fractals ?
3 Aug 2010 at 16:53 #6 Jfan Jfan Associate Joined 22 Aug 2005 Posts 542 ooEy said: 1 more quick question. If I connect the pump to a molex can I use the Fractals fan controller for the 2 x 120mm Fractals ? Click to expand... You wont need fan controller for the fractals, they really are silent
