Hi all - I have just built a system with the above case and have just took delivery of more case fans and a better fan than the original corsair one that comes with the h-50 cooler..
I don't know if I am correct but I would like to run the top two exaust fans and the h50 fan via the 3 fan controller that comes with the case. I have wired it all up but noted that I had to remove the cpu fan from it's conector on the mobo to conect to the controller.. Cooling is fine but i get the error msg telling me I have no cpu fan connected.
So can somebody tell me if it is possible to do this and if so how do I go about conecting the conroller to the 4 pin cpu fan connector?
thanks
thanks
