Fractal R2 - soundproofing
1 Feb 2006
I have had one of these cases for about 3 years and only just noticed inside that there is a plastic covering over some of the sound proofing material in the removing sides. Is this something that I should have removed when I got it?
I only happened to notice as the plastic had bubbled up in one small area otherwise I wouldn't even have noticed that there was a plastic layer at all. I'm guessing that I've been using this case for 3 years without getting the proper benefit of the noise deadening features!
No I don't think you should remove it as it's part of the sound dampening material. It would not of made any difference with or without the plastic
