Recived my case afew days back i poped everything in there in a non-OCD-Addict way and here is the good bad and the ugly.
+ Great Sound Proofing can't hear my Antec 620 in there.
+ Nice minimal LEDs ont he power button.
+ Plenty of cable routing holes in MOBO Tray.
+ Plenty of fan mounts.
+ Tonnes of room between the back of the mobo tray and inside of the side panel for cables.
+ USB 3 on case front.
- PSU fan filter does not fit flush on underside of case.
- Rubber gromets fall out if you just think about puting a cable near them.
- no rubber gromets for fans mounted to the top of the case.
- Top of the case is as flexy as a trampoline and vibrates away like something from ann summers.
- Rear mounts for Graphics card / Raid card / Soundcard looks like they forgot about it and then welded it back on and is ****ed at a slight angle.
- Side panels are stiff and don't locate into the slots nicley ( Requires some force )
- Front door foam is very thick no chance of having a DVD/Blueray drive with pertruding buttons ( NON-FLUSH)
- No chance of installing anything but a touch screen fan controller 1 slot high.
- lack of height between MOBO top I/O and 120mm mounted fans / thin radiator.
- Front Panel wires ( not including the USB 3 / USB ) are slightly short for some MOBO's
All in all its a bit of a mash of quite good and ah whoops we forgot to screw our heads on, so many little things let this case down !
If your just popping some mid ranged components in here its fine, but if your going for 290mm triple height or double height cards or SLI your out of room !
Don't even think about getting a double length radiator in there on the top fan mounts even with just PULL fans let alone PUSH PULL.
