Essexboy, what GC are you using in your define R4?
Not GC at the mo but am a bit worried for space as i have a dh-14 cooler and there is not much room on the pci 16 slot next to it.
Will probably get a 770
Just changed the fan setup, with a bit of reading, i need to change the rear intake to exhaust again.
i have atm, 2 intake front
1 intake rear (conflicting with nh-d14 i think)
2 exhaust top
so i need to do;
2 intake front, (140mm akasa viper)
2 exhaust top, (120mm fractal case fans)
1 exhaust rear (140mm akasa viper)
is this the best setup for my fans?
some ideas please
