I want to achieve good airflow when I re-build my machine into a Fractal R4 case later this week.
I'm thinking of going with the following;
2 X 140mm intakes at the front
1 X 140mm intake at botton / side still undecided
1 X 140mm exhaust at the rear
1 X 140mm exhaust at the top rear.
I have seen advice that you shouldn't use both the top rear and rear as an exhaust and that it's better to reverse the top and use it as another intake, doesn't make a huge amount of sense to me, something to do with compeiting airflow? I should achieve positive pressure in the case with 3 intake to 2 exhaust.
Any advice on the placement of the third intake i.e. side vs bottom? GPU does get pretty hot so either should help. Ideally I want max airflow without sacrificing the silence of the case to much.
Thanks in advance
Thanks in advance
