- 1 Jul 2007
Received my Fractal R4 and decided to put in my new mobo and CPU tonight, and come across a few queries.
I bought this BNIB from ebay, unused and only opened to check that everything was there. Even the plastic cover on the front was on.
1) Came with three fans, the third being an Akasa DFS122512L. Has this happened before?
2) Instead of being 9 mobo mounts and screws only 8 of each was there.
3) What's the blue "ss" cable? Is it for the USB front ports?
With points 1+2, unless this has happened before, I sort of suspect that it may have been used for a review. Some odd marks on screw tops here and there but nothing like that is 100% from factory.
