On the fractal R4 you can mount SSD's on the back of the motherboard tray, but the problem is that you have to screw it from the motherboard side, which would involve completely removing motherboard and then rebuilding the whole PC just to install an SSD.....
Does anyone know where I can get some sort of double sided screws or something so I can mount SSD's on the back of the motherboard tray without removing the motherboard first?
