Fractal R5 spares help
4 Nov 2018
Seem to be going round in circles and looking for some help. I'm after a 5 bay cage/tray/mountings for my Fractal Design R5 case as going for something similar to this.
Fractal Designs spare centre have the cage, but not the trays or mounting kit in stock. They've advised theres no plans to restock in the near future either, as its an old model case. I can't find anywhere else that stocks them, including eBay, so kinda stuck.
Does any one know where I could get spares or have any ideas?
It's replacing my 3 bay cage, so I could buy the 5 bay cage from Fractals spare centre and use the 3 trays I have. So would just need 2 trays and mountings.
I might be able to design and 3D print the trays (and make them compatible with standard hdd screws). However would need a tray as a reference to be able to make all the measuremments. Or if you're good at CAD you can prepare the model and I can print as many as you need for cheap.
Thanks for the offer Vykku, after an original cage/mount/tray so they match the others, keep it looking neat and tidy.
