- 30 Oct 2014
- Norfolk
So for 3 months, I had a 280mm Radiator installed for a liquid cooler, so hence..had to remove the sound dampened panels.
Long story short, took it apart, positioned radiator in a different corner, all done.
But..the top panels, on the curved sides of the panels, one side fits perfectly,the other doesn't slide all the way in. So middle can't go in..is it due to metal being bent or idk..tried everything.There just a tiny gap of the curved one to the case..like I can put my nail between the gap and move it.
