Looking at a HTPC build for the front room, picked up the Fractal ridge case as my wife, and I, approve of it visually, and it will fit in the tv stand horizontally.
Essentially need it to be able to play 4k video and be quiet whilst doing it. The ability to play games on it would be nice, but not the priority. Would like to keep the budget under £700 (not including the case). Any build suggestions/advice would be greatly appreciated.
www.fractal-design.com
Ridge
An uncluttered, small form factor case designed to integrate seamlessly into your living space and daily rituals. An evolution of the slimline format, Ridge was developed in collaboration with gaming and entertainment enthusiasts to subtly improve their homes and enhance the small form factor PC...
Compatibility
- Motherboard compatibility
Mini ITX - Power supply type
SFX, SFX-L - Side radiator
120 mm when ≤175mm long GPUs are installed (280 mm without GPU) - PSU max length
SFX-L - GPU max length
325 mm with SSD installed. 335 mm without SSD installed. - GPU max height
125 mm with top fan(s) installed, 137 mm without top fans - GPU max thickness
57 mm with 2x 140 mm fans installed, 82 mm without side fans - CPU cooler max height
70 mm
