Been happening for last few months now and only just recently have I tried to get to the cause of the problem. Basically any game I play, no matter the harddrive it's installed on seems to be giving me problems. I have a quick frame skip and usually audio skips out. They usually go hand in hand in terms of both taking place at the same time. Sometimes that isn't the case and I just have some slight frame stutter without any audio hitches. Its very random and happens may be once every 2-5 minutes but sometimes I can go for 5-10 minutes without any hiccups. It's very jarring and frustrating.
I've ran a couple of programs to try and pin point the issue and one of them is LatencyMon, which gave me this error message:
Your system appears to be having trouble handling real-time audio and other tasks. You are likely to experience buffer underruns appearing as drop outs, clicks or pops. One problem may be related to power management, disable CPU throttling settings in Control Panel and BIOS setup. Check for BIOS updates.
And a screenshot to go with it here:
Finally a large report output:
I'm hoping it's more of a software issue which I why I chose to put the thread in here over the hardware section
. It suggests a BIOS update but my motherboard is from 2010 and my CPU isn't overclocked or underclocked. My soundcard is Xonar DG and hasn't had any new driver support in years from what I gather and hasn't seemed to cause me any trouble in the past but I wouldn't completely disregard anything at the moment. I've also used afterburner with HWINFO for on screen feedback and my graphics card is running under normal temperatures.
I'd love any replies you guys can give me. I've probably missed something glaringly obvious.
_________________________________________________________________________________________________________
CONCLUSION
LatencyMon has been analyzing your system for 0:07:57 (h:mm:ss) on all processors.
SYSTEM INFORMATION
Computer name: DAY-PC
OS version: Windows 7 Service Pack 1, 6.1, build: 7601 (x64)
Hardware: H55M-S2H, Gigabyte Technology Co., Ltd.
CPU: GenuineIntel Intel(R) Core(TM) i5 CPU 760 @ 2.80GHz
Logical processors: 4
Processor groups: 1
RAM: 8155 MB total
CPU SPEED
Reported CPU speed: 2799.0 MHz
Measured CPU speed: 3250.0 MHz (approx.)
Note: reported execution times may be calculated based on a fixed reported CPU speed. Disable variable speed settings like Intel Speed Step and AMD Cool N Quiet in the BIOS setup for more accurate results.
MEASURED INTERRUPT TO USER PROCESS LATENCIES
The interrupt to process latency reflects the measured interval that a usermode process needed to respond to a hardware request from the moment the interrupt service routine started execution. This includes the scheduling and execution of a DPC routine, the signaling of an event and the waking up of a usermode thread from an idle wait state in response to that event.
Highest measured interrupt to process latency (µs): 16685.714286
Average measured interrupt to process latency (µs): 8.026717
Highest measured interrupt to DPC latency (µs): 248.685714
Average measured interrupt to DPC latency (µs): 3.977138
REPORTED ISRs
Interrupt service routines are routines installed by the OS and device drivers that execute in response to a hardware interrupt signal.
Highest ISR routine execution time (µs): 109.329046
Driver with highest ISR routine execution time: USBPORT.SYS - USB 1.1 & 2.0 Port Driver, Microsoft Corporation
Highest reported total ISR routine time (%): 0.020076
Driver with highest ISR total time: hal.dll - Hardware Abstraction Layer DLL, Microsoft Corporation
Total time spent in ISRs (%) 0.038129
ISR count (execution time <250 µs): 532637
ISR count (execution time 250-500 µs): 0
ISR count (execution time 500-999 µs): 0
ISR count (execution time 1000-1999 µs): 0
ISR count (execution time 2000-3999 µs): 0
ISR count (execution time >=4000 µs): 0
REPORTED DPCs
DPC routines are part of the interrupt servicing dispatch mechanism and disable the possibility for a process to utilize the CPU while it is interrupted until the DPC has finished execution.
Highest DPC routine execution time (µs): 266.873526
Driver with highest DPC routine execution time: cmudaxp.sys - C-Media Audio WDM Driver, C-Media Inc
Highest reported total DPC routine time (%): 0.540508
Driver with highest DPC total execution time: cmudaxp.sys - C-Media Audio WDM Driver, C-Media Inc
Total time spent in DPCs (%) 1.033510
DPC count (execution time <250 µs): 4219438
DPC count (execution time 250-500 µs): 0
DPC count (execution time 500-999 µs): 2
DPC count (execution time 1000-1999 µs): 0
DPC count (execution time 2000-3999 µs): 0
DPC count (execution time >=4000 µs): 0
REPORTED HARD PAGEFAULTS
Hard pagefaults are events that get triggered by making use of virtual memory that is not resident in RAM but backed by a memory mapped file on disk. The process of resolving the hard pagefault requires reading in the memory from disk while the process is interrupted and blocked from execution.
NOTE: some processes were hit by hard pagefaults. If these were programs producing audio, they are likely to interrupt the audio stream resulting in dropouts, clicks and pops. Check the Processes tab to see which programs were hit.
Process with highest pagefault count: msmpeng.exe
Total number of hard pagefaults 192
Hard pagefault count of hardest hit process: 107
Highest hard pagefault resolution time (µs): 98393.684530
Total time spent in hard pagefaults (%): 0.074638
Number of processes hit: 15
PER CPU DATA
CPU 0 Interrupt cycle time (s): 25.178736
CPU 0 ISR highest execution time (µs): 102.674169
CPU 0 ISR total execution time (s): 0.383563
CPU 0 ISR count: 477134
CPU 0 DPC highest execution time (µs): 266.873526
CPU 0 DPC total execution time (s): 13.572865
CPU 0 DPC count: 3420130
CPU 1 Interrupt cycle time (s): 4.900799
CPU 1 ISR highest execution time (µs): 109.329046
CPU 1 ISR total execution time (s): 0.030509
CPU 1 ISR count: 4724
CPU 1 DPC highest execution time (µs): 240.712755
CPU 1 DPC total execution time (s): 0.379208
CPU 1 DPC count: 44421
CPU 2 Interrupt cycle time (s): 8.666147
CPU 2 ISR highest execution time (µs): 88.395498
CPU 2 ISR total execution time (s): 0.208942
CPU 2 ISR count: 32722
CPU 2 DPC highest execution time (µs): 167.045016
CPU 2 DPC total execution time (s): 2.137049
CPU 2 DPC count: 214940
CPU 3 Interrupt cycle time (s): 14.988652
CPU 3 ISR highest execution time (µs): 102.006431
CPU 3 ISR total execution time (s): 0.105468
CPU 3 ISR count: 18057
CPU 3 DPC highest execution time (µs): 261.600214
CPU 3 DPC total execution time (s): 3.656869
CPU 3 DPC count: 539949
CONCLUSION
SYSTEM INFORMATION
Processor groups: 1
RAM: 8155 MB total
CPU SPEED
REPORTED ISRs
REPORTED DPCs
PER CPU DATA
. It suggests a BIOS update but my motherboard is from 2010 and my CPU isn't overclocked or underclocked. My soundcard is Xonar DG and hasn't had any new driver support in years from what I gather and hasn't seemed to cause me any trouble in the past but I wouldn't completely disregard anything at the moment. I've also used afterburner with HWINFO for on screen feedback and my graphics card is running under normal temperatures. I'd love any replies you guys can give me. I've probably missed something glaringly obvious.
