Frame Generation crashing games (possibly solved)
8 Jul 2011
Rosyth, Scotland
Hi,
I just upgraded from a 3080 to a 4090 and I'm having trouble with 3 games in particular, Cyberpunk, Diablo 4 and The Witcher.
When I have Frame Generation enabled the games just close by themselves all of a sudden. No driver crash or anything like that, they just close. I can play for hours at max settings with RT on but as soon as Frame Generation is enabled the game will crash within a few minutes.
I have completely removed any trace of old drivers using DDU in safe mode and closed all background programs/services to try and rule things out.
Event Viewer doesn't show any errors when this happens either.
This happens at both stock and OC on the GPU.
Any idea?
Interesting. For me the out-of-the-blue crashing in CP2077 happened in relation to dynamic resolution being on (perfectly fine off), but I don't think the other 2 have DRS. Usually such crashes happen as a result of a memory leak, so perhaps with FG on that's what happens. Sometimes the issues are entirely game/driver/windows related and out of your hands. F.ex. I couldn't launch No Man's Sky on Steam for like 6+ months ever since they did a major game overhaul BUT found out the game launched perfectly fine on GOG (drm-free ftw). Now with the newest update I can launch it on steam again. Didn't change anything on my end, they just messed up along the way somehow. Sadly troubleshooting can be a real PITA sometimes on PC.
Was it a fresh windows install too?
Any possibility of trying the card in another system?
I could try in another if it came to it.
It's just strange that everything works fine without FG then crashes with it. I didn't fresh install Windows.
What's your PSU?
My 3090 did that a lot on an older PSU due to transient spikes and I had to replace it.
Allegedly the 4000 series don't have spikes as bad as the 3000's but I bet they still have them.
Try under clocking and undervolting to see if it still happens.
I think this may have ended up being related to the Nvidia overlay or the Sharpen+ filter. I normally apply about 15% sharpen to my games because I like the way it looks. Last night I was playing Dying Light 2 for a couple of hours with FG enabled and had no issues. I then applied the filter and within 2 minutes I got a CTD. I then tested Cyberpunk with no filter and managed to play for a long time without it crashing. After applying the filter it crashed after 5 minutes. I'm going to go off of this being my issue unless something else comes to light.
