Frame Protection
18 Oct 2002
Fife, Scotland
I just took delivery of my first road bike and I'm wondering if anyone bothers about protecting the underside of the frame on a carbon bike?
I bought a Defy and I don't think I'd put mud guards on it, doesn't seem to be any room anyway. So what do you guys do, just leave it bare or protect it somehow?
Nonb question... But I want to keep the bike looking good for as long as possible, lol.
Cheers!
Got my first new road bike arriving next week (only bike so far was bought used and has seen better days).
I'll slap some of my car detailing products on it, most notably over the front forks right up in to the arch and all around/over the chain stay and around the BB. etc. (Poorboy's Wheel Sealant).
Was wondering myself if anybody bothers with added protection around the chainstays to protect against any chain slap etc? I have a travel skewer to keep everything in place during transport but **** still happens.
Helicopter tape for about the first 6 months until I realise it looks terrible and I stop believing my bike will be perfect forever.
I use thick black tape like stuff, but then I know roadies like there bike looking all nice and clean so maybe not for you. It also helps reduce the chain slap noise.
Lizard skins make patches to stop cable rub around the head tube and chain slap.
But yeah, nothing stays immaculate forever. The first cut is the deepest, as they say, but you'll get over it.
If you're talking about the things I'm thinking of then I got similar ones with my Jagwire kit but they fell off in less than a thousand miles. Electric tape seems to stay put pretty well.
Mine have stayed put. Of, course they've stayed put in slightly the wrong place so there's still some rubbing on the head tube. The one on the chainstay was impossible to get on flat so is a bit open at the front and full of dirt. And I don't doubt that if I tried to take them off to replace them then they'd take a load of paint off with them! Gah!
I used to treat my bikes the same as my car and waxed them but it is a bit of a faff as unlike a car you don't have nice big panels to work on, just lots of little nooks and crannys to get wax residue stuck in. So now I use a silicon spray as a polish and protection.
As for cable rub, luckily my cables came with rubber sleeves that go on the contact points. Chainstay came with a clear shield, when that eventually comes off the chainstay can can just get chipped. In the past I've used neoprene covers and they seem to trap dirt. Any sort of sticker normally does the same around the edges after a while too.
Cheers for the replies guys, quite a few ideas!
I've just ordered Bike Shield, just to cover the underside until the whole new bike thing wears off lol
Weekend can't come quick enough!
