- 6 Nov 2017
My frame times are all over the place and there is seemingly no reason or nothing I can do about it. They do not correlate to my frame rate, nor do they make ANY sense.
I began having stutter/hitch issues in everything a few months ago. I did an insane amount of troubleshooting before throwing in the towel and buying all new hardware. The stuttering is worse in Open world titles and also with video.
My frame times are terrible in everything as seen here. This is taken from a few minutes in scum, but it's the same story in every title, minus less demanding ones like Rainbow Six.
Frametime (spikes are stutters): https://imgur.com/a/PpYbpmn
Gpu temp and power is fine: https://imgur.com/a/MskEv8N
Core clocks are stable: https://imgur.com/a/r0FXsXj
Cpu temps are fine: https://imgur.com/a/7rC4G7m
Yet I still have terrible frame times. I have replaced all of my hardware except the Motherboard and Psu (which was changed earlier this year). I did try a new Mobo, but with my older components, to no avail so I reverted back to my old one. I put the new CPu, and Gpu and Ram in the old one again (having ruled it out as a problem), so maybe it is killing something crucial off?
None of the Hardware shows any sign of problem that I can tell while monitoring, such as High temps, voltage issues, clock dips etc. The issue is widespread and affects all title and videos.
I have done 100+ hours of troubleshooting
So far I have.
Specs;
I7 4790
Gtx 1070 Strix
16gb 1600Mhz
Samsung Evo 960
Evga g2 650w
So far I have.
- Changed all of my PC components (to an i7) Psu, RAM, SSD, Cables, 4 different Gpu's including two 1070's. Tried a different MOBO, but it didnt change so placed new components into my old mobo.
- Tried every different combination of windows settings, optimisation I can think of.
- Tried multiple different fresh windows versions on different drives.
- Installed only basic software.
- Changed Bios settings and profiles, tuned of iGPU
- Looked at temps, voltages and profiles.
- Tried about 10 different Nvidia drivers
- Lowered graphical options and other settings like Sync
- Ran many tests like userbenchmark, furmark, prime95, passmark uni engine (which stutters too)
Specs;
I7 4790
Gtx 1070 Strix
16gb 1600Mhz
Samsung Evo 960
Evga g2 650w
