Download: http://www.fraps.com/
FRAPS 2.9.5 RELEASE NOTES
The latest Fraps version contains a new DirectDraw (DDRAW) video capture engine for early DirectX games. It also allows us to support early windowed titles, with most DDRAW games now recorded at full speed.
Vista sound recording has been updated with the option to capture in either Stereo or Multichannel modes. Not all video editors can support multichannel audio so you can now force Fraps to record in Stereo even if you have a 5.1 or 7.1 speaker setup.
This release also contains many bug and stability fixes as outlined below:
CHANGELOG
- Added Stereo & Multichannel recording options for Direct Stream audio in Vista
- Added support for many DDRAW games running in windowed mode
- Added support for games that use multiple swapchains in D3D9
- Added large size icon for Vista
- Fixed slow video capture speeds recording many older DDRAW games
- Fixed capture crash for DDRAW games in XP SP3
- Fixed misaligned audio with Vista Direct Stream when sound was silent
- Fixed 64-bit OpenGL apps not being detected
- Fixed long delay starting video capture on some Vista configurations
- Fixed crash in Fraps if video capture key pressed quickly in succession
- Fixed Fraps exit dialog appearing at random intervals
- Fixed 'This program might not have installed correctly' error in Vista
- Fixed corrupted volume slider in Vista when Fraps loaded
- Fixed scrambled colors when recording in 8-bit and 16-bit from some older games
- Fixed crash loading levels in Wolfenstein: Enemy Territory
