Fraps Not Working
Permabanned
9 Mar 2010
Fabric Nightclub, London.
Hey guys.
As per title, really. Normally I get 180 fps on MW2, but whenever I run fraps (recording to a separate HDD) it keeps jumping, cutting out and then finally crashing the game. any ideas?
recording takes a lot of CPU power, so try recording at a lower res or FPS rate. failing that i hear the beta version of MSI afterburner is a very good recorder (has to be the beta version to get sound)
Yes, but I should be fine with CPU power, my 2500k is at 4.6 ghz =\
I've tried afterburner, and that produces terrible video and stutters worse than fraps. Not good.
MSI AfterBurner compresses the video as well, hence why it produces worse video stutters and the default video quality is set at 85% for some reason, while recording at half size. You need to change this in the settings to uncompressed, 100% quality and full size. That should produce a better video quality and less stutter while recording.
