Hey, just looking for a bit of advice, I've been using fraps for a while now to record some of my game play in TF2 amongst other games and my PC can do this no problem. In the near future I will be looking to do the same for Bad Company 2 and possibly other games yet to be released.
At this moment in time im using...
i7 920 OC'd to 3.8GHz
6GB triple channel ddr3
HD 4870 - currently 750/900MHz
Samsung SpinPoint F1 1TB
Obviously more than enough for TF2 I get 155fps average when benchmarking with fraps. What steps would you guys recommend I take to minimize the performance drop when recording newer games?
). Try that, see if it helps. Might not though
. Basically, MikeHunt's suggestion will be the best improvement, then consider my suggestions if you still want to
