Freaky usb problem
4 Jan 2009
kingston-upon-hull
Hi all
Turned my pc on today and my usb wi-fi adapter (d-link dwa-111) was not working no light on and windows xp was not detecting it as if its not plug in so plugged it into the port next to it and it worked.
So tried 2x usb thumb drives my keyboard and mouse a xbox 360 pad ect ect all worked fine so I plugged it back in to the original port and nothing.
As it was a port on the case I swapped it from the first usb header on the motherboard to the second header and what do you know it worked in the same usb port on the case that it wouldn't work in before I swapped motherboard headers.
So just wondered has anyone come a cross something like this before and any idea what's going on I just find it strange that up to this point it was working fine.
Don't know if its case, motherboard or the adapter?
spec:
athlon 7750be
gigabyte ga-ma770-ud3
collermaster rc-590
palit 9800gtx+
2x1gb corsair xms3
samsung 320gb+250gb
pc power & cooling 750w quad crossfire
2xdvd-rw
logitech lx710 keyboard and mouse
Thanks all
