Free 24-bit Studio Master quality tracks
19 Oct 2002
South London
Enjoy a complimentary download of 15 tracks from world-renowned music system manufacturer Linn and experience music in 24-bit Studio Master the highest quality available anywhere
Use the enter promo code MASTER on checkout
Link
Thanks for this, tried out the tracks last night and it was quite lovely.
However I can only get a 16/48 signal to my DAC instead of the 24/192.
I have the PC hooked to a FiiO E17 via optical out and player is Winamp. Windows 7. Any suggestions on the settings I need?
Sorry not sure what the problem could be i play music via a Raspberry Pi2 and a Meridian Explorer 2 DAC and the music is passed to the DAC at 24/192
Have you set 24/192 or 24/96 in the windows playback settings for the output?
There's no difference to my ears other than 'maybe' less grain.
Aune T1 24but DAC amp and Philips Fidelio x2
How do you check what bit rate and hz it's playing at?
Normally if all 3 lights are lit on my Meridian Explorer 2 its being feed 24-bit but strangely Rune Audio tells me there 32-bit :confused:
Cheers, I got round to it last night and it now outputs at 24/192.
However it doesn't automatically switch 16/48 when I play a normal mp3. Is that usual that you have to manually change the settings back?
Missed this when it was originally posted. Thanks to the OP and those that bumped it! Downloading now.
Tech wise, I'll play these on my HTPC via HDMI to my AV amp.
