Free code generator
13 Jan 2004
South East
Hi all, I need to create a lot of unique codes for a client (into the tens of thousands). Does anyone know of a website where you can specify the format for the code and then it just outputs this for you?
Thanks
EDIT: I found one after I posted this that does up to 20,000. Nevermind.
Thanks
I was gonna say Excel
=RANDBETWEEN(10000,99999)
copy it down, copy and paste the whole lot as 'values' then do a 'remove duplicates'
Why bother with random?
A consecutive list from 10000-99999 would be pretty much the same.
And they'd be easily guessable if he's using "ten of thousands" of codes from that select list.
Yes, sorry, i wasnt suggesting that way was a good idea. Just that randomising it then removing duplicates is not a particularly efficient way of producing that list.
He said he wanted the numbers to 'random'
I misread, I thought the 'codes' he wanted had to be 5 figures long.
It'd take me less than a minute, how much more efficient do you want, It's certainly quicker than typing up a thread on here about it.
Your method would eventually give every number between 10000-99999. It doesnt matter what order they are in if you include every number.
He said he wants a lot of codes. Once he starts to get towards the end of the possible numbers that your method creates, it would start to take a long time.
...produce random number
...remove duplicates (random number gets removed because it's a duplicate)
...repeat until a non duplicate is produced.
As I already said, I misread. I thought he wanted an unspecified number of random numbers in the tens of thousands (5 digits). So I wasn't advising taking 10 thousand random numbers between 10000 & 99999.
My mistake.
